Hi! 🙂
My surge will not sync my ride to Strava. It has been 12 hours or so, I've tried deleting both apps, deleting my Fitbit connection from Strava, logging in and out. Is there anything else I can do? I can't figure out how to revoke access on Fitbit 🤓 Thank you!!
Hi @Meggyblanch! It's great to see you participating in our Community! Welcome! ![]()
Thanks for the details, I'm just wondering if you tried all steps using a computer. If you did so, you've tried all the steps that we could try from our end, I would consider contacting Strava Support directly; take a look of the Resources for the Strava App. I hope the issue gets solve soon!
Keep me posted on the resolution! ![]()
I just got a surge and it's not syncing with Strava either. Even though I only _just_ linked the accounts, I went through the steps of unlinking and relinking, and no dice. No problems (ever) with my Microsoft Band account previously syncing, and my Magellan MioShare account has no problems syncing.
Nice to see that you're digging into the Forums @BuckarooBanzai, let me give you a warm welcome to our Community.
Thanks a million for sharing that information, if your tracker is syncing your stats; it should be feeding your Strava stats too. At this moment we don't have any information from Fitbit having issues connecting with Strava. When you're new, it might take a couple of hours to properly connect; if not you can try these steps. Thanks for bringing this information to our attention.
If nothing works contact them directly. You can check the Resources for the Strava App. I hope the issue gets solve soon! ![]()
Let me know if you have further questions about this. ![]()
