09-03-2016 23:26
09-03-2016 23:26
Best Answer09-03-2016 23:34
09-03-2016 23:34
Best Answer09-05-2016 07:46
09-05-2016 07:46
Hi @Nedcelkel, it is nice to see new members around! Sounds cool that your Surge back on. But not so great that now it is neither syncing nor swiping through the screens. For syncing issues on iOS devices, I suggest you to follow the instructions on @AlejandraFitbit post. If it is not swiping, only a restart can help, so I will suggest you to fully charge your tracker and then perform a restart. If that doesn't work, please contact Fitbit Support, I'm pretty sure they will find an alternative solution for you.
Let me know the outcome! ![]()
Best Answer09-05-2016 15:19
09-05-2016 15:19
Best Answer09-06-2016 08:34
09-06-2016 08:34
Great @Nedcelkel! Let me know the outcome.
I'm pretty sure that Support will give you the best solution as they always do. Don't worry.
Have a nice day!
