No replacement bands available for the Surge at this time @SunsetRunner
designed as a single piece and hard glued on.
You might vote up that feature in "feature suggestions" - it's been declined; but you never know 🙂
"Status changed to: Declined
This is a technical limitation. The Surge tracker isn't designed to be interchangeable with other bands since the tracker is built into the wristband."
Great idea though.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
@SunsetRunner Amazon offers aftermarket replacement bands for the Surge. YouTube has videos on how to change them. I recommend you watch the video and decide if it's something you or someone you know can do. If it is then get the replacement band. Good luck!
