11-30-2018
00:34
09:21
YojanaFitbit
11-30-2018
00:34
09:21
YojanaFitbit
Hi Fitbit Support,
Due to a sports fall, the Action Button (right top) of the fitbit looks partially jammed. And I am guessing, this is affecting the menu swipe actions. For instance, I goto the RUN menu with a Home Button (Left Middle) press, it does not allow me to swipe left or right to move to the other menus. Is there a way to fix this problem ?
Thanks,
RPD
Moderator edit: Updated subject for clarity.
Nice to see that you're digging into the Forums @rprasad, let me give you a warm welcome to our Community. ![]()
Thanks for reaching out the Forums. Have you tried the restart:
Your tracker should now work normally. If your tracker still doesn't work after a restart we will have to check the options with support.
Keep me posted.
21:15
06:20
YojanaFitbit
12-02-2018
21:15
06:20
YojanaFitbit
I had contacted the support and got the following reply:
Hi @rprasad, @Shed and @patty309. Thanks for reaching out and trying the suggested steps.
@rprasad thanks fa million for the help. Sorry that you didn't get the option to get a replacement but thanks again for sharing this workaround.
@Shed and @patty309 I've noticed that you've already got in touch with our support team, thanks for that. They will give you all the details about your Fitbit warranty and future options. Rest assure I'll pass along the feedback, your voice is being heard. Fitbit is always reviewing your responses to provide feedback to our product development team.
Let me know if you have questions about it.
Hi @Shed, thanks for the heads up! I'm glad to know that your Fitbit is working now! In case that you need anything else, please let me know.
I'll be around. ![]()
