02-04-2017 05:37 - edited 02-04-2017 05:38
02-06-2017 06:36
02-06-2017 06:36
Hi @tlm1972! Thanks for getting back. Not so sure about if it's gonna happen soon, in this moment we don't have more information in regards when the list will be updated, but stay tuned! We usually have information posted in the Community. Remember that you have the option to use a computer or any other compatible device in the meantime. You will find information on how to connect in a computer in this master post. ![]()
Let me know if you need anything else! ![]()
02-04-2017 08:40
02-04-2017 08:40
Is the device you are trying to sync to a supported device?
iOS: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_iOS.pdf
Android: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_Android.pdf
Windows: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_Windows.pdf
02-04-2017 08:44 - edited 02-04-2017 08:46
Thanks for stopping by guys @tlm1972! Welcome to the Forums. Thanks @SunsetRunner for jumping in! I've checked that model in the list of Supported Devices, but Huawei P9 is not listed. You can try these steps, to see if this is able to connect, but since some devices don't meet all the requirements to connect properly with Fitbit, we cann't assure some features like Notifications, Setup or Syncing will work flawless. ![]()
As a friendly tip, check that you're phone is running the latest update, it might hep too! ![]()
Good luck and let me know if you need anything else! ![]()
02-05-2017 03:26
02-05-2017 03:26
Thanks for the quick reply 🙂
It seems that Huawei P9 isn´t supported, according to the list. Some of the other Huawei phones are supported.
I just got this phone (used to use iphones) and didn´t check if this one was supported. I really hope it will be supported soon, but maby someone knows if it´s gonna happend?
02-06-2017 06:36
02-06-2017 06:36
05-28-2017 18:18
05-28-2017 18:18
Hi Yojana,
Another P9 user cranky at finding my Blaze won't get notifications from my phone. I have noticed a lot of moderators saying that connecting to a PC or another device is the accepted solution to this issue. How about making it clear on the packaging that not all phones are supported so a better buying choice can be made. Do you really think shelling another $500 to $1000 (yeah... I pay the Australia tax) is an acceptable solution? And I don't see how connecting to a PC is going to fix my notifications from my phone issue. I realise you are a moderator and probably a volunteer doing the best job you can, but could you please use whatever influence you have to make these clowns understand that this issue is really upsetting people. I have been looking at posts from January where this is a problem. It's nearly June and nothing seems to have been done. Unless something changes soon, this will be the last Fitbit device I ever buy.
05-31-2017 09:42 - edited 05-31-2017 12:16
Hi @scottydblaze! Please receive a warm welcome to the Fitbit Family! It's great to see you participating in our Community! ![]()
Thanks for placing your comments here, sorry for the inconvenience with your Blaze. When a phone is not a compatible device with Fitbit, there are some permissions and requirements that are missing to have a good connectivity for all features. I think that the suggestion that they are proving you was to solve a different inquiry, since connecting from a computer could help to update the firmware or sync with your tracker, but not with notifications as you mentioned too.
Fitbit is always looking forward to improve products and services, our engineering team is still working on the Fitbit platform to make it compatible with this and other phones that are not compatible yet. I really appreciate your patience in all this regards. It'll be a matter of time so my best advice is stay tuned to possible updates. Are you currently able to use your Blaze and sync? If not, let us know so we can help you further! ![]()
About the question in regards to the packaging, you will see the information in one side of the Fitbit package. (see attach picture)
Have a great day and please don't loose your motivation, keep walking! ![]()
