02-07-2017
01:09
08:18
MarlenS
02-07-2017
01:09
08:18
MarlenS
I have a Fitbit Surge which has water inside, or at least condensation on the inside of the screen. It also fails to swipe to give me information, although it still reports to my iPhone. I've been very careful with it as it was a present from my daughters. I've never worn it in the rain, and done anything else such as washing hands or showering while I'm wearing it. I do exercise to the point where I sweat, and if there has been sweat under the Surge or band then I wipe it off with something clean and blow on the charging socket to remove any other moisture. Again I've been very careful with it, and I'm 71 so I don't get too wild anymore. Can someone help me please?
Best Answer02-08-2017 08:14 - edited 02-08-2017 08:17
It's great to see you in the Community @PeterBiggs! ![]()
I moved your post from Charge to Surge board so this can help other users with the same concern. The Fitbit products were designed as water resistant, this means that this is only rain, sweat and splash proof, we don't recommend to use it while showering, as with any wearable device, it's best for your skin if the band stays dry and clean. My recommendation is to place the Fitbit in a bowl of rice for 48 hours, then restart the Surge and check if the display works again.
Let me know if you have questions. ![]()
What's for breakfast?Check others recipes and share yours!
Best Answer02-15-2017 12:33
02-15-2017 12:33
Best Answer02-16-2017 11:21
02-16-2017 11:21
Hey @PeterBiggs, it's great to see that you've visited the Fitbit Community! Thank you for trying to place your Fitbit in rice and I'm sorry to read that it does not work. I've sent you a PM to continue working this issue with you.
See you around. ![]()
