01-13-2016 06:39
01-13-2016 06:39
07:13
08:42
01-13-2016
07:13
08:42
Hey @Genowaldron, it's great to have you here in the Community! Ok let me just confirm something, when you say that your Surge is not working, what exactly do you mean? that the display is not working or that is not syncing? or what is the specific issue you are having?
Please let me know so I can help you out better.
Best Answer01-13-2016 08:39
01-13-2016 08:39
09:15
08:42
01-13-2016
09:15
08:42
@Genowaldron Thank you for getting back to me! ok let's try to do something, first of all restart your Fitbit Surge, then follow these instructions to set up your Surge as a new device, that should update the software and display the correct time and should sync properly.
Please let me know if that works and how the battery is draining.
