02-28-2016
23:28
06:01
CindyFitbit
02-28-2016
23:28
06:01
CindyFitbit
in setiing I turned off the bluetuth but sevice still connect with phone,
Battery doen't last for four days!!
Moderator Edit: Updated title for clarity.
Best Answer02-29-2016 05:57 - edited 02-29-2016 05:58
Hi @nasserawadalla welcome to the Community! f you aren’t tracking runs or exercises that use GPS, your fully charged Fitbit Surge should last up 7 days. I recommend checking other tips to maximize your tracker's battery life. If the issue persists after trying my recommendations the best step is contacting support so they can evaluate your case.
Keep me posted! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
Best Answer02-29-2016 06:59
02-29-2016 06:59
My battery isn't lasting long either. I had to charge it Saturday afternoon and this morning it barely made it through my walk. And I just went to sync it now that I am at work and it says the battery is low again.
Is this something normal?
Best Answer03-01-2016 05:54 - edited 03-01-2016 05:54
Hey hey hey @AprilBlackard! That doesn't sound like the expected behavior, please try the recommendations on my previous post.
Keep me posted!
Best Answer03-01-2016 07:58
03-01-2016 07:58
I'm getting 2 days Max on my new surge. This is ridiculous! 😞 Right now I'm #41 in line for live chat.
03-02-2016 05:52
03-02-2016 05:52
Hey @KelliG1970! Have you tried my recommendations above? About getting in touch with support, in case you were not able to contact them, I suggest calling at (877) 623-4997 M-F 4am-8pm // Sa,Su 6am-5pm (PT).
Let me know how it goes!
03-03-2016 22:07
03-03-2016 22:07
What else is continuous on your watch? Hr. rate? Did you delete the Bluetooth settings out of your phone as well? I found on my Alien ware laptop that there is 3 Bluetooth signals the Bluetooth adapter has active.
You can turn off your adapter, but clear your phones Bluetooth connected devices. Most phones... heck all use the Wi-Fi adapter to push Bluetooth. That is why your 4G gets crapping when your phone is Blue toothed to a car, etc.
If you have an Android turn off your Bluetooth, go into settings, Application Manager/ Go over until you get to running programs (and STOP every instance of Bluetooth you can see in the Running Applications.
Restart your phone and see if the Bluetooth services are still running in the background on your phone.
They shouldn’t be but if they are that could be the reason why your Surge is not lasting.... maybe not?
Hope this helps a bit.
Best Answer03-08-2016 12:51
03-08-2016 12:51
Many thanks for your contribution @SunsetRunner, I'm sure this info can be useful for a lot of users! ![]()
Have you checked our Discussions board? There you can share your story, find some fitness tips, recipes and more! Give it a look!
See you, I'll be around!
