01-01-2016
12:56
09:10
AlvaroFitbit
01-01-2016
12:56
09:10
AlvaroFitbit
My Surge used to work fine, but now i cannot reset or turn off when in exercise mode. I work out or run and all seems to be fine but I have to reboot the watch completely to reset back to standard mode. Obviously a general reset does not solve the problem. Seems like the top right button no longer works. And the watch is only six months old. I had a great Garmin for years and never had any issues. Is the HR monitor worth the tradeoff for a watch that is so poorly made? Anyone else have this issue?
01-02-2016 01:10
01-02-2016 01:10
If it's a software problem then multiple restarts should address it (this doesn't always work first time so several tries are recommended):
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-restart-my-tracker/
If it's a hardware problem (which sounds likely) then you should still be within warranty (you can check at www.fitbit.com/returns ) in which case you can contact customer support via: http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
