05-06-2016 08:44
05-06-2016 08:44
When exercising in cooler weather, my surge gets condensation under the watch face. Once that happens, I'm unable to swipe. Love the product for all my training, etc., but this is now startng to be problematic. I've had the watch for about 9 months. Any assistance would be appreciated.
Best Answer05-06-2016 11:52
05-06-2016 11:52
Hi @Kirby56 welcome to the Community!
Sounds too bad that your Surge is getting condensation on the screen. In this case you have to contact Customer Support, so they can take a look of your account and your warranty options. I'm pretty sure they will choose the best one for you.
Let me know how it goes! ![]()
Best Answer07-24-2016 04:52
07-24-2016 04:52
Best Answer07-25-2016 05:10
07-25-2016 05:10
Welcome to the Community @Sassytati!
well, I've heard a few cases where the hot weather is related to condensation on the screen of the Fitbit Surge and what I normally recommend is performing a restart. So I urge you to try that and if that doesn't work, please contact Fitbit Support.
I'll be around! ![]()
Best Answer07-25-2016 06:37
07-25-2016 06:37
Best Answer07-26-2016 07:27
07-26-2016 07:27
Thanks for your response @Sassytati!
As I mentioned, the weather could be related, but it shouldn't affect all the time how the Fitbit Surge works. So probably your Surge might be defective, so let me suggest you to get in touch with Fitbit Support as I previously mentioned, 'cause they have the tools to investigate this and provide you with a solution.
Let me know the outcome!
Best Answer07-26-2016 12:18
07-26-2016 12:18
Best Answer07-26-2016 12:32
07-26-2016 12:32
I just got off Chat with support. They wanted me to reset, which i had done 5 minutes earlier. They had me re-sync to get reset info online. Still was not working/swiping. I was still under warrranty
so i am getting a surge sent to me(not sure if refurbished or new) and recycling the old one at an electronics recycling center. Hopefully everyone is able to get a working one.
Best Answer07-26-2016 13:15
07-26-2016 13:15
Best Answer07-27-2016 05:36
07-27-2016 05:36
@Sassytati sounds great that Support replaced your tracker with no problem.
@myshawrona to be honest with you, I'm not sure if the tracker will be a completely new one or a refurbished one.
@SunsetRunner I'm very sorry to hear about the experience you have had with Customer Support. If you have any other question or issue with your tracker, keep me posted, maybe I can help you out.
Have a great day guys! ![]()
