07-21-2017 01:38
07-21-2017 01:38
My surge has been fine for ages but has suddenly started giving me to many calories. Originally when I wake up I have 500 calories which is about right, but lately I have 2500ish when I wake up. I don't generally wear my watch while sleeping. Its also showing as being active while its just sitting on the sideboard.
07-22-2017 08:05
07-22-2017 08:05
Thanks for joining this family, hope you like what find here @banjolilywhite! ![]()
It's very odd you're getting more calories than usual when you're not wearing your Surge. Usually you just get the calories that are coming from your Fitbit Account since it uses your basal metabolic rate (BMR) to generate calories everyday, even when you don't wear it. Where do you put your Surge at night? Are you getting steps too? Are you manually logging activities? ![]()
It might be that your Surge is sensing movement or vibration at night and that's why you're getting information. Why don't you try to "Shut down" your Surge at night. It might help!
I'll be around! ![]()
Best Answer07-26-2017 04:28
07-26-2017 04:28
Hi
Have tried shutting it down/restarting ect.
This morning it shows as 2500 calories on wake up with no steps taken or floors climbed. on the dashboard it also shows as this. However when I go into the calories it shows a more realist 513 calories???
07-27-2017 06:16 - edited 07-27-2017 06:20
Hi @banjolilywhite! Thanks for confirming what you've tried already. Not sure about what is happening! ![]()
I'd like to know where you put your tracker at night, to see if there is any chance that it might be getting the vibration of the TV or any other device. Is it near to the AC? I'd like to check with you in the PC using the Fitbit.com Dashboard, your stats for those days. Once you've logged in into your Fitbit Account, tap on "Log" > "Activities" and let's check at what time are those steps and floors are being recorded.
If you can add a screenshot of your findings, that'd be great! ![]()
I'd recommend restarting your Surge in case it is having hardware issues!
