08-19-2017 11:48 - last edited on 08-21-2017 04:48 by MarreFitbit
What are they....
08-19-2017 12:01 - edited 08-19-2017 12:02
Voice cues can come from your mobile, enabling your voice cues is really easy just do the following:
Hope this helps and keep us posted on your progress, great to meet you.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
08-20-2017 04:15
08-20-2017 04:15
08-20-2017 11:47
08-20-2017 11:47
With the App running your mobile will tell you stats on the current run/walk you are doing. The frequency it speaks can be set for minutes or miles, you choose how often. It can speak cues to you on the Distance, Time, and/or current pace.
WmChapman | TX
08-20-2017 23:20
08-20-2017 23:20
08-20-2017 23:20
08-20-2017 23:20
07-07-2019 04:59
07-07-2019 04:59
For the life of me I can’t find a + on the dashboard. I’ve done everything that is suggested. Help, please.
07-07-2019 05:01
07-07-2019 05:01
07-14-2019 13:11
07-14-2019 13:11
The + is in a green circle on the front screen when you open the app.
07-16-2019 05:08
07-16-2019 05:08
Can voice cues be set up to do a run walk pattern? For example. I want to do a 5 minute walk and then 8 intervals of 30 sec run and then 2 minute walk?
07-28-2019 12:29 - edited 07-28-2019 12:31
@DebbiMoses Those instructions are for a different version/layout of the app. To find this now, tap on your exercise tile > the stopwatch > continue with the rest of the instructions.
@taskr_mom No, they are things like a cue every half mile. It's not an interval trainer.
Laurie | Maryland, USA
03-02-2020 08:04
03-02-2020 08:04
If I do this, will mymy fitbit device be used to track my heart rate?
06-08-2020 22:44
06-08-2020 22:44
Can I get voice cues for average heart rate for each Km along with other voice cues
01-08-2021 20:15
01-08-2021 20:15
Is this still applicable? I don't see a + in the upper right corner. I am using an android phone, if that makes a difference. I purchased a Versa 2 in October and would love to be able to use this feature.
