07-02-2016 20:52
07-02-2016 20:52
My watch band has broken on the underside of the watch by the two screws towards the top, seems kind of weird but others have had the same issue. Should I call someone or just post this?
Best Answer07-03-2016 13:07
07-03-2016 13:07
Hi, @SunsetRunner! You should contact Fitbit Support directly. This forum does have some Fitbit employees in it, but for actual support questions, you should go there. If possible, it will speed your inquiry if you can include images of the damage. Good luck!
MakMak | Community Council
