Hi,
As part of my efforts to improve my health and wellbeing I am trying to increase my daily water intake.
To do this I would like to split my water intake into several slots throught the day so that i am optimally hydrated.
Is there any way i can set up reminders in the fitbit appplication and sync them with the watch for this task?
If there isn't then maybe it would be a good idea for fitbit to implement this function as it would make water tracking easier.
You can check out the alarms and see if that will work for what you need.
Under settings.
Wendy | CA | Moto G6 Android
Best AnswerWhen going to the toilet and the water is darker.. it's a sign needing to drink more. If it's lightly yellow or clear, it means having drinked enough.
If noticing signs like lips / tongue feeling dry.. it also indicates to have to drink more.. ![]()
A warm welcome to the Fitbit Community @tom221! I think that your idea is a great suggestion to be implemented on our Fitbit product, I found a similar suggestion that has a lot of votes already. Take a look of this request in this post and vote for it if you like it. ![]()
In the meantime settings alarms sound really helpful! Thank you @WendyB for this great option. ![]()
Catch you later. ![]()
