06-20-2016 04:28
06-20-2016 04:28
Best Answer06-27-2016 14:25
06-27-2016 14:25
Thanks for joining us @Boshop! Keep in mind that your Surge's HR algorithms were designed for a whole day tracking and the Polar strap is for specific workouts and periods of time. You might want to restart your Surge by doing the following:
After doing that keep an eye to your HR behavior. Also, I've found a way of testing your HR. Click here for more info about it (even if this has been posted in a Charge HR thread it's applicable to the Surge as both trackers have an HR monitor).
Another thing to consider is making sure you are wearing your tracker correctly. Try with placing your Surge higher on your wrist; because blood flow in your arm increases the farther up you go, moving the tracker up a couple inches can be helpful. Also, make sure you're not wearing your tracker too tightly; a tight band restricts blood flow, potentially affecting the heart rate signal. After a short wait, you should see your correct heart rate again. If this reading persists, try changing your Heart Rate setting from "Auto," which means the heart rate tracker is usually active when you're moving, to "On," which means the heart rate tracker is always active. Then, try relaxing your wrist and staying still briefly about 10 seconds, after which you should see an accurate heart rate reading. Note that your tracker will still provide accurate calorie burn readings during these types of exercise by analyzing your heart rate trends over the course of the workout.
Let me know how it goes, I'll be around! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
