01-05-2016
15:18
16:36
VivisFitbit
01-05-2016
15:18
16:36
VivisFitbit
I'm in Wales and we get a lot of rain. Was wondering if it's ok to wearing when running in wet weather or when showering.
Moderator Edit: Subject for Clarity
01-05-2016 15:27
01-05-2016 15:27
Hello @alysonattawar,
Welcome to the community!
As per their description:
"Fitbit Surge has been tested up to 5 ATM meaning it is sweat, rain and splash proof. However, the device is not swim proof. We also recommend taking Fitbit Surge off before showering because, as with any wearable device, it’s best for your skin if the band stays dry and clean."
I hope this helps.
They don't recommend your wearing it in the shower, but that's mostly because it's then more likely to irritate your skin.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
06-01-2016 15:13
06-01-2016 15:13
Hello there guys! @stmacqua I'm sorry to know your Surge is fogged. If you're buddy is still not working, I highly recommend contacting our Support friends. Rest assured they'll take good care of you. Thanks so much for sharing your tip @jmitchel53.
Keep it on the good way!
01-05-2016 15:24
01-05-2016 15:24
This is what happend when I wore mine in the rain today 😞
https://community.fitbit.com/t5/Surge/6-mile-run-in-the-rain-with-the-Surge/m-p/1099218#U1099218
-Justin
01-05-2016 15:27
01-05-2016 15:27
I hope this helps.
01-05-2016 17:21
01-05-2016 17:21
03-14-2016 17:46
03-14-2016 17:46
05-06-2016 16:44
05-06-2016 16:44
Hello there guys! Thank you for your participation in the Community. You can wear your Fitbit trackers it is raining and even during the sweatiest workout, since they are water-resistant.
We don't recommend swimming with your trackers. Whenever you get your tracker wet, dry it carefully before putting it back on.
05-18-2016 06:11
05-18-2016 06:11
Hi Vivian,
Monday I wore my firtbit surge in the rain for a run (CB). It wasn't downpouring, just a lite drizzle. Today the screen is fogged up and I can no longer swipe to see steps, stairs etc. It still counts steps, which I can see on my phone. I can send a photo of the screen if it would help.
It is less than 1 year old and I use it EVERY day 😞
Thanks
Stephanie
05-18-2016 09:36
05-18-2016 09:36
Hi Stephanie,
I had the same problem with my Surge a while back which I reported in an earlier thread. It's happened a couple more times since then, but fortunately, after 8-24 hours, the condensation does evaporate and then the touch screen will start working again. One thing I found is that running with it in the rain with a short-sleave shirt typically isn't a problem, but it's when I have a long sleeve shirt or jacket on that covers that watch and creates water vapor that gets into the watch and causes problems. Hopefully this flaw will be fixed at some point, but until then, letting it dry out with likely fix the problem and functionality should be back to normal soon.
-Justin
06-01-2016 15:13
06-01-2016 15:13
