Weekly amount (leaderboard) of steps not updating
So my daily activity has been syncing throughout the day but the weekly under the community has not updated since midnight. I’ve tried restarting both my Fitbit and phone as well as removing the Fitbit and adding it back in the Fitbit app. Any ideas on how to fix this?
Moderator edit: Updated subject for clarity.
6 REPLIES 6
I have the same problem, but no steps have loaded since about a week ago on the community “friends” page
It’s so frustrating. At least the daily is showing up but I like seeing my step amount for the week. In the past it wouldn’t always update on one sync, but it would on the sync a little bit later in the same day. Today that wasn’t happening.
Sent from my iPhone
Exactly!!! I just got mine to work FINALLY!
After reading some of the posts, I tried logging out 2 or 3 times and it worked!
Just go to your Fitbit account settings and scroll to the bottom, log out, and then sign back in. You may have to do it 2 or 3 times.
It worked for me-hope it does for you!!!
Moderator edit: removed personal info
If that fix doesn't work for you then keep an eye on the following thread which has the latest updates from fitbit on this issue:
https://community.fitbit.com/t5/Fitbit-com-Dashboard/Friends-Leaderboard-not-updating-updating-slowl...
Thanks for the help!!!
Hi @Giggles2082 and @44pepperNice to see that you're digging into the Forums, let me give you a warm welcome to our Community. Smiley Happy
Thanks for your patience! As our good friend @SteveH mentioned, it sounds like the issues with leaderboard that @KateFitbit mentioned a few days ago. You can check the latest details in her post here.
See you around.
