01-02-2016 15:51
01-02-2016 15:51
Best Answer01-02-2016 15:52 - edited 03-30-2020 14:02
On the computer Dashboard: Click on the gear and go to settings./ Scroll down to exercise shortscuts and you will see how to move them
You can try dragging them around on the phone.
Wendy | CA | Moto G6 Android
14:22
09:18
03-23-2020
14:22
09:18
Look for exercise short Cuts and you can add it there.
Moderator Edit: Personal info removed
Best Answer03-24-2020 06:47
03-24-2020 06:47
@azioazio I just want you to know that I asked a moderator to remove the links you have included in all of your posts. They aren't related to Fitbit and could be going to malicious sites. If a moderator doesn't remove the links in a reasonable amount of time, I will be removing your complete posts to protect the site and its users.
You can edit your posts by tapping on the ellipsis in the upper right, then Edit Post. I don't want to remove your posts. You have some good information to share.
Laurie | Maryland
