Where can I buy a nylon strap for a Surge?
I have been looking for a nylon replacement strap for my fitbit surge as the silicone rubs my skin and leaves a red, dry mark. Does anyone know if nylon straps are available for Surge and where i can get a reasonably priced one?
Thanks
4 REPLIES 4
You can not replace the strap on the surge.
You can try
https://www.etsy.com/
They might have something to cover it up and protect your arm
Community Council Member
Wendy | CA | Moto G6 Android
@Missmadness Amazon and E-bay sell aftermarket bands for the Surge (as Fitbit does not consider them replaceable). YouTube has "How to" video's to help. Good luck.
Fixed wing aircraft (F-4J, F-4S), Fighter Squadrons: VF-171, VF-31, VF-103.
Hi. Thank you for your reply. I have checked both sites but cannot find any
nylon straps. Will keep looking.
Thanks for your reply. That's odd as I have found replacement straps just
not nylon ones that i am after.
