05-08-2016 07:58
05-08-2016 07:58
Runs seem like they should be "activities"... and I would like to have them show up on my profile.
Thanks!
05-09-2016 10:36
05-09-2016 10:36
Welcome to the Community @megkds ! Well, they should be there after syncing.. Would you mind to show me where you're looking at?
Are you syncing after ending your exercise? Plus, are you checking this on your website or the Fitbit app?
05-09-2016 12:24
05-09-2016 12:24
I have the same problem on my profile (the page that my friends would see). For some reason none of my workouts show up after April 25th (runs, walks, weights). I have activities that I've logged with my blaze and see them in my dashboard, just my friends cant see them. I searched the forum and it appears to be expected behaviour related to the release of the Charge HR?
05-09-2016 13:23
05-09-2016 13:23
Please both of you go to the Privacy Settings, and make sure that the option that says "Activities" is enable to "Friends" and not to "You" or "Anyone". Keep in mind that the activities that your friends can see are the ones that are in the "Activity Log" sections not the "Recent exercise" tile.
Hope this helps @SeeChrisRun @megkds!
05-09-2016 13:59
05-09-2016 13:59
05-09-2016 13:59 - edited 05-09-2016 14:05
also, those are the same activities (under "activity history" and "recent exercise")... i'm talking about when i do an activity (like go for a run...) and record it with my Fitbit Surge (which i thought was the point of getting it)
05-09-2016 14:14
05-09-2016 14:14
@SeeChrisRun, are you also having major GPS issues when you run? (even though i wait for the GPS to engage before starting - like i did with my Garmin - it cuts out for huge sections of each run, which my Garmin or iphone don't do. i've also had it put me a whole street over from where i was running.)
05-09-2016 15:00
05-09-2016 15:00
I actually haven't used the Blaze with GPS yet. My brother has a surge and I believe it works ok for him. Maybe someone with a Surge could post thier experience with it. Sorry!
05-09-2016 15:02
05-09-2016 15:02
Just checked the privacy settings and my Activies are set to "Anyone". Is there any other setting that would affect this?
