08-10-2020 12:09
08-10-2020 12:09
I have the original Surge, as well as the first Blaze. Will they be able to keep up with the new software updates? I haven't used them in well over 2 years.
Best Answer08-12-2020 13:10
08-12-2020 13:10
No it should work with the app. They still support it but dont expect any updates for it
Wendy | CA | Moto G6 Android
08-10-2020 15:10
08-10-2020 15:10
They are considered obsolete so you will not see updates for them unless its a problem that needs to be addressed
08-12-2020 10:22
08-12-2020 10:22
Does that mean it will not work, or interact with the app?
08-12-2020 13:10
08-12-2020 15:12
08-12-2020 15:12
I should add no updates for blaze either. But are still supported but are obsolete so no updates for it either
