06-06-2019 15:27 - edited 06-06-2019 15:28
Hello,
I understand that active minutes are “awarded” based on your heart rate being held above a certain threshold.
However, what I don’t understand is this:
I go for a 53 minute walk, and my heart rate is between 90-114. I am awarded 53 active minutes.
I set my FitBit to “workout” and I row for 90 minutes, with my heart rate between 90-128/95-134, depending on my cadence. I am awarded *0* active minutes.
The only way I can be “awarded” those rowing active minutes if I use “workout” is by logging them in MyFitnessPal. FitBit then grants me 90 active minutes when the apps sync.
A few days ago, I was given 7 minutes for walking around the grocery store and pushing a cart.
And today, I was awarded 9 minutes—simply for working on my terrace garden. My heart rate would not have gotten even as high as the walk.
Why would the terrace work, pushing a grocery cart and the walk grant me active minutes, while the rowing session with the higher heart rate for a longer time grant me 0 minutes?
“Workout” for a recumbent bike session also awards 0 minutes. I only get credit for the session if I use “spinning”, or I log the session in MyFitnessPal.
As a test, I tried setting my FitBit to “spinning” when I used my rower yesterday for 80 minutes.
I made sure to keep my heart rate up and sustained and at a good rate. For 10 of those minutes, I made sure to pull at a good clip—to the point where I was breathing hard.
I was awarded 79 active minutes. (I’m not going to complain about a loss of 1 minute.)
Please explain why neither rowing nor recumbent cycling don’t count as active minutes if I use “workout”, but “spinning” does.
As a note: If I set my FitBit to “workout” and I walk on the treadmill, I do get active minutes.
Is it because I’m seated that “workout” doesn’t work?
Restarting my FitBit, and/or uninstalling and reinstalling the app does not yield a solution. I have tried several times. I have also tried removing the FitBit from my account and reconnecting it.
Thank you,
Heather Self
Best Answer06-07-2019 21:02 - edited 06-07-2019 21:04
Rowing is not step based. It will never be accurate.
I always manually log these types of exercise
Wendy | CA | Moto G6 Android
Best Answer06-08-2019 13:11
06-08-2019 13:11
Thank you for the reply, but, per the subject line of my post, my question is why I get 0 *activity minutes*—not steps. I’m aware rowing and cycling do not yield steps.
Best Answer06-12-2019 07:35
06-12-2019 07:35
Both rowing and recumbent (stationary cycle) are non detectable to Fitbit. Use spinning that may be found on your wrist to record your stationary bent. See question 2
How do I track my workouts with my Fitbit device?
Best Answer06-16-2019 11:06
06-16-2019 11:06
Hi @HCSelf, I'm sorry but I can't help with your lack of registered active minutes. But as to the rowing I have a charge 2 and I select elliptical as a substitute. Do you have that option in the surge? If you do it might be worth a try.
Cheers.
Best Answer06-16-2019 11:32
06-16-2019 11:32
Best Answer05-12-2020 17:24
05-12-2020 17:24
I don’t get active minutes when I used my recumbent bike when I select The
Spinning exercise.
