03-20-2017
09:13
11:58
YojanaFitbit
03-20-2017
09:13
11:58
YojanaFitbit
My time is off by 29 minutes. How do you reset?
Moderator edit: Clarified subject.
03-22-2017 11:56
03-22-2017 11:56
Welcome to the Forums @7755Keith and @Harrynlil!
In case that you need more help with the time on your Surge. First thing you have to try is sync it. If your tracker is not currently syncing you can follow the steps in this master post from @HelenaFitbit. Checking the settings on your phone and Fitbit App would be the second step, both should be set in "Automatic time zone".
You will find the option on the Settings on your phone and on your Fitbit App. If you're using an iOS phone check this post from @VivisFitbit. For Android > Settings > Time and Date > Time Zone > Automatic. Once you've check that information on your phone, you can go to the Fitbit App > tap on Account > Advance Setting (for Android > Settings) > Time Zone > Automatic.
Catch you later!
03-20-2017 10:27
03-20-2017 10:27
How do I reset to correct time
03-22-2017 11:56
03-22-2017 11:56
Catch you later!
