11-21-2017
02:10
03:23
YojanaFitbit
11-21-2017
02:10
03:23
YojanaFitbit
To me, notifications are very important. Since Fitbit supporto for phone is terribly slow, I am still using an old phone in order to still have notifications. Unhappy but fine.
However, since last firmware update, I can't get any notifications (phone calls and whatsapp).
Do you have any hint to solve this?
11-24-2017 03:22
11-24-2017 03:22
Hi @Intero, hope you're doing great!
Thanks for reporting the unusual issue with your notifications. What model of phone you're using? Did you check for any update for your phone or Fitbit App. I'd consider checking these instructions to reconnect notifications. Please let me know if you encounter any error or message.
Keep me posted!
11-24-2017 03:22
11-24-2017 03:22
Keep me posted!
11-28-2017
09:02
11:40
YojanaFitbit
11-28-2017
09:02
11:40
YojanaFitbit
Thank you, it worked with the "If these steps didn’t work, try restarting your tracker and then turning notifications off and back on" part.
ps. it was a galaxy note 3, with latest app installed.
after 1 call and 1 whatsapp notification, it stopped working again and I missed the next call.
I'll try the last step in your procedure but honestly I really don't like my Fitbit anymore!
i went through the whole procedure but it still isn't working at all.
Thanks!
11-28-2017 11:34 - edited 11-28-2017 11:52
Thanks for replying @Intero, sorry to heard that you feel that way. Please try the last steps one more time and remember to check the Notifications option and make sure Enable Notification Widget is on.
I'll be around if you need anything else.
11-29-2017 01:46
11-29-2017 01:46
I did and it's still not working.
11-29-2017 11:24
11-29-2017 11:24
Hi @Intero! Thanks again for your patience and working through these troubleshoots! Keep an eye on your inbox for next steps our team will be getting in touch with you shortly.
Let m know if you have questions.
11-29-2017 11:34
