05-13-2016 09:41
05-13-2016 09:41
Best Answer05-13-2016 10:16
05-13-2016 10:16
Have you set your Time Zone? On the Dashboard click on the gear and go to settings Scroll all the way towards the bottom. Use the drop down to select the right one. It needs to sync before it will take place.
Wendy | CA | Moto G6 Android
Best Answer05-13-2016 10:17
05-13-2016 10:17
If from the Phone its also under settings.
Best Answer05-13-2016 13:29
05-13-2016 13:29
same but is just the time is 3 minuts late
Best Answer05-13-2016 13:33
05-13-2016 13:33
