08-11-2018 08:27
08-11-2018 08:27
If I replace my surge battery, will it continue to add to the history of my data?
Best Answer08-11-2018 14:03
08-11-2018 14:03
@beanburl wrote:If I replace my surge battery, will it continue to add to the history of my data?
yes
only if you're successful
Best Answer08-14-2018 03:16
08-14-2018 03:16
you can replace the battery?
Best Answer08-30-2018 12:50
08-30-2018 12:50
Yes and no @radzi, Fitbit advises against this. My feeling is if it is past the warranty then the tracker is mine to do what I want. Since the warranty is up, does it really matter?
As mentioned above, the risk has to weighed, but do a search of YouTube.
