08-20-2016 03:22
08-20-2016 03:22
Hi everyone,
I've been struggling quite a bit to get my device to sync since the first time (after I've read numerous discussion forums), but I emailed the Fitbit team and this was the response (it worked for me). Please be advised that I'm using a Fitbit Surge, from a Windows PC.
Please be informed that syncing issues are often caused by a missing requirement. For this reason we'd like to verify if each requirements are met:
If all the requirements are met and your tracker isn't syncing, please confirm to us if these were the troubleshooting steps that you've done:
1. Initiate a manual sync:
2. Check if your tracker synced by clicking the gear icon in the top right of your fitbit.com dashboard. You'll see the last sync time below the tracker name.
3. Restart your tracker using the instructions in How do I restart my tracker?
3. Uninstall and reinstall Fitbit Connect using the instructions in How do I reinstall Fitbit Connect?
4. If your tracker didn't sync and you have access to a mobile device, try syncing with the Fitbit app instead.
Hopefully this post would help at least one other person as well.
Kudos.
Elmi
08-21-2016 08:30
