03-28-2018
20:35
11:12
YojanaFitbit
03-28-2018
20:35
11:12
YojanaFitbit
My tracker is nt detected during sync.
Problem arose after charging the device
03-29-2018 03:04
03-29-2018 03:04
I had the same problem this morning. I tried again later in the day and it works fine now. Not sure what was the problem in the morning. I exported the .tcx file and the data is null. Basically, it did not record any data except for the basic stuff like timing, bpm and distance, nothing beyond that.
03-30-2018 02:39
03-30-2018 02:39
This same situation started for me a couple of days ago also but has not corrected itself. I also have noticed my surge battery drains very fast, I have to charge every day. I'm a long time user and have tried all the resets. It will only sync 1 time after the tracker is turned off and then back on.
04-01-2018 11:34
04-01-2018 11:34
Over the last couple of days it has been hit or miss. Started to work then stopped again and the tracker battery dies.
04-01-2018 12:40
04-01-2018 12:40
Mine is doing the same
04-02-2018 06:19
04-02-2018 06:19
Something interesting happened this morning. I was using my cell which is what I use to sync my surge. I received a system message on my cell that read "Bluetooth connection rejected by Surg". Never seen that before.
04-02-2018 11:26
04-02-2018 11:26
Mine is doing the same thing
very frustrating
04-05-2018 13:44
04-05-2018 13:44
Well, well, well..... a fitbit app update today and now my surge is syncing again without the huge battery drain. Every update is always a guessing game...... will it work or will it mess things up. I'm glade it's back working but I still find it frustrating.
04-07-2018 11:09 - edited 04-07-2018 11:16
Hi @SunsetRunner and @Tommy632 thanks for joining! @rbittira and @JackieSmall welcome to the Forums!
As @Tommy632 mentioned, you can try to update your Fitbit App in case that you haven't done so. Take a look of the steps in this article: Why won't my Fitbit device sync? And if you're getting an specific error message or code let me know.
Thanks for the update @Tommy632, please know that we take your feedback very serious, it helps us to improve connectivity and services. Your comments are very important for us.
I'll be around.
