Hi,
I am trying to setup my device-
I have been trying to update my surge; I have synced the device with my account. but when its request an update, following the sets leaves me an error 'sync your fitbit.... with 5 steps'. The device is already synced according to the dashboard.
thanks
@tcowan72 Welcome to the Fitbit Community! It's great to have you here! I hadnt heard this issue before. However, allow me to help here. You can try restarting your tracker so it refreshes itself internally. After this, setup your Surge as a new device and the firmware update one more time.
If the workaround does not do the trick, my friend @Anna1118's recommendation is the best tip to follow. Our Support team will investigate further and get you back on track.
Hope this helps and catch you later! ![]()
