06-29-2017 06:30
06-29-2017 06:30
How do I reset the time on my fitbit Surge? It is off by 8-10 minutes.
Best Answer06-29-2017 07:36
06-29-2017 07:36
HOW DO I RESET?
Best Answer06-29-2017 11:32 - edited 06-29-2017 11:34
Welcome to the forums!
First thing I would check is to make sure the time on your Phone and computer are correct.
If they are on the computer
Go to the dashboard and click on the gear choose settings. Then scroll down to time zones. change it to something different. Let it sync and then go back and change it to the correct one. Let it sync again
Phone: Click on the disk upper right hand corner this is settings. Scroll scroll down to advanced settings and choose Select time zone. Do the same as above by changing it to something different and back again
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
