Hi i have a surge fit bit for day to day activity but want to wear a smaller one for work. Could I use two fit bits on the same account and would it add both sets of info together....
IE walked 10k with surge
walked 1k with other fit bit for work
on my fit bit page 11k walked for the day??
thnaks hoped i explained it ok
Best AnswerHi @doofuss1993
It's possible to have multiple trackers linked to the account, though each must be of a different model. So no two Surges..
Feel free to check out the Fitbit Article:
Best AnswerHello and welcome to the forums @doofuss1993
You sure can do that. Just be sure to sync your Surge before putting on the other Fitbit. The steps will all show on the one account so you can see them combined.
Which other Fitbit will you use? You can't have two of the same type on one account.
You explained it just right.
Keep on stepping!
