09-20-2017 03:14
09-20-2017 03:14
i have a question regarding the firmware of the Surge, right now I can only track my running although the app shows that I "could" track yoga, rowing, and other activities yet I do not have them as a choice on my surge setting.
is there an upgrade that will allow to use those too? as it is listed as I should be able to track other activities yet on the app and Surge watch are not available to pick them as an activity even thou they are listed!
thanks
09-20-2017 06:21
09-20-2017 06:21
@PatriIRE, there are no updates for the Surge and haven't been for several years; that said, while the Surge has a number of exercise modes (hiking, spinning...), I don't believe I've ever seen yoga or rowing as options.
09-20-2017 09:47
09-20-2017 09:47
@PatriIRE Your activity selection is in your Fitbit Dashboard. Click on "Settings" (the gear to the upper right). Select "Settings" from the dropdown menu. Then "device settings" located to the left. Scroll down to the bottom and click on Exercise Shortcuts. Click "Edit" and make your selections. Up to 7. Yoga is there but I don't see Rowing. Once you make your selections click "Save". Be sure to Sync your Surge for the changes to take effect. Good luck.
09-20-2017 10:02
09-20-2017 10:02
@VF31AE3 wrote:@PatriIRE Your activity selection is in your Fitbit Dashboard. Click on "Settings" (the gear to the upper right). Select "Settings" from the dropdown menu. Then "device settings" located to the left. Scroll down to the bottom and click on Exercise Shortcuts. Click "Edit" and make your selections. Up to 7. Yoga is there but I don't see Rowing. Once you make your selections click "Save". Be sure to Sync your Surge for the changes to take effect. Good luck.
Ahhh, good call, I had forgotten about the ability to tune the exercises.
09-22-2017 02:24
09-22-2017 02:24
thanks for this!
09-22-2017 02:38
09-22-2017 02:38
I tried that but it will not let me select another activity. you are right there is no rowing or yoga but aerobics etc. i can only see that the app should recognize different activities but i cannot actually pick another activity from my surge directly or my app ....
thanks again for your help
