Best AnswerIt is indeed possible, but you'll need to get your hands a bit dirty with the Fitbit API.
https://wiki.fitbit.com/display/API/API-Get-Device
Collin | Los Angeles, California
One, Charge HR, Aria - Android 5 (Moto X), Mac
Take a look at the Fitbit help site for further assistance and information. Help others while waiting for help!
The developer APIs are for accessing information on Fitbit's server, which contain data as of the most recent sync. If you are not a developer, it is not for the faint of heart.
Recently, Fitbit also opened up a channel on IFTTT (If This Than That) but I don't think one of the triggers is the battery level. Otherwise this would be a very easy way to do your own logic when the battery is low.
Other options to consider:
1) In your settings (website gear icon) visit Notifications > Low Battery and enable SMS or email
2) At the bottom of each webpage is a link to an App Gallery, one of which is a low battery notifier
See https://www.fitbit.com/apps/lowbattery
