11-11-2022 19:41
11-11-2022 19:41
My runs have stopped syncing to strava. I have followed all the standard advice (disconnect and reconnect the sync, log out, update apps, turn off phone, sync again). The same thing happened a couple of weeks ago and the disconnect and reconnect method seemed to work but not today.
Is anyone else having the same issue? Fitbit is still writing my activities to another app so I think the issue may be more
on strava’s side.
any ideas on how to fix would be much appreciated!
11-12-2022 10:28
11-12-2022 10:28
Confirmed - started 2-3 days ago.
Strava API seems to work fine (I used https://www.fittostrava.com/) and normal integration is hosted by Fitbit (http://strava.fitbit.com/) so I think this is purely on Fitbit side.
11-13-2022 08:11
11-13-2022 08:11
Do you have Android phone? Did you accept Health Connect integration recently?
Best Answer11-13-2022 14:29
11-13-2022 14:29
No, I am using apple. I didn’t change any settings around the health app integration before the sync issue started
11-13-2022 15:40
11-13-2022 15:40
I did....would that cause it to quit updating?
Best Answer11-13-2022 20:52
11-13-2022 20:52
Probably not, I just tried running after disabling Health Connect and it didn't help.
11-20-2022 03:47
11-20-2022 03:47
I'm also facing this issue. Any help would be greatly appreciated.
11-23-2022 07:41
11-23-2022 07:41
Have run into the same issue and began sometime this month. I've done all the steps (forget this device, revoke access, updates, etc) as found in older forums and still have to manually upload it via downloading tcx. I have the versa3 andit syncs via iphone
11-24-2022 13:00
11-24-2022 13:00
Just heard from Strava....they say it's fitbit not pushing it to them. So much finger pointing....so little answers. Does anyone from fitbit ever read these?
11-24-2022 16:39
11-24-2022 16:39
Fitbit support told me they are working on it last week.
11-30-2022 05:59
11-30-2022 05:59
did you get a response from the support team on this?
11-30-2022 06:03
11-30-2022 06:03
Afraid not. Still not syncing so relying on manual uploads for now
11-30-2022
06:56
21:02
YojanaFitbit
11-30-2022
06:56
21:02
YojanaFitbit
Just got this reply today after debating there is no way my iOS version is the issue (its not).
There is no timeframe but at least they confirmed they know theres some issue. I have no idea how it can be a problem with their app but hope they get this fixed soon.
At least now I know its not me and I will stop trying to reconnect FitBit and Strava connections every day.
Moderator Edit: Formatting / Word choice
11-30-2022 07:15 - edited 11-30-2022 07:15
@ilaudor wrote:did you get a response from the support team on this?
Nothing more than they are looking into it. Instead of waiting I bought Samsung Galaxy Watch 5 and I'm mostly happy about it.
12-01-2022 16:54
12-01-2022 16:54
