07-21-2017 09:31
07-21-2017 09:31
I have linked my fitbit and myfitnesspal accounts and still cannot get the information from my fitbit to sync into myfitnesspal. Driving me nuts because I'm burning up more calories than fitnesspal thinks so not getting accurate projections from it at the end of the day. HELP!
Best Answer07-24-2017 06:53
07-24-2017 06:53
Hello @colnana08, good to see you again in the Fitbit Community! When it comes about integrations, in this case MFP which is not syncing your information; the best to try is to reconnect both accounts.
Follow the directions from this post and make sure to connect your tracker as well for all your calories sync correctly.
Keep in mind the way the information is shared as this play an important role when it comes about this integration.
| What syncs? |
| Fitbit > Steps > MFP |
| Fitbit > Calories > MFP |
| Fitbit > Aria measurements > MFP |
| MFP > Logged food > Fitbit |
| MFP > Activities > Fitbit |
Hope this helps and see you around!
07-24-2017 06:53
07-24-2017 06:53
| What syncs? |
07-25-2017 06:20
07-25-2017 06:20
Best Answer07-26-2017 07:34
07-26-2017 07:34
Hello @colnana08, hey I'm glad to hear you were able to fix the issue with MFP! I like to hear great news and thank you for keep me posted.
For anything else you know where to find me. Stay awesome!
Best Answer01-30-2018 14:43
01-30-2018 14:43
Have read your instruction re syncing Fitbit with MFP = did not work for me. Have revoked fit bit in MFP & reconnected = didn’t work! Have done this 3 times with no joy! Pls help as I’m using 1900 Cals/ day but no exercise data is being picked up in MFP
Best Answer02-07-2018 09:45
02-07-2018 09:45
Hi there @Bulaggimoo, welcome aboard to the Fitbit Community! Please accept my apologies for being absent from this thread.
I saw you are experiencing syncing issues with MFP, despite following the steps I suggested before.
According to MFP suggestions try to force a sync with your accounts to see if this works:
Once you have verified Fitbit is connected, you can try to force a sync. Not before review your Fitbit has synced to the Fitbit dashboard.
Once data is flowing from your device to Fitbit, you can manually add a cardio exercise to your MyFitnessPal diary, such as walking for two minutes (you can delete the entry later if you like). Within 15 minutes (usually sooner) this should force a sync for your Fitbit adjustment.
If this is not happening, please feel free to contact MFP customer support for some extra help.
Don't forget to keep me posted. I'm always around!
Best Answer02-07-2018 10:14
02-07-2018 10:14
