Hi guys,
I am able to change the daily water target at the Dashboard (web) from the default value to let says...2000ml.
But over at the android version of the Fitbit app fails to show the new target value.
Do you guys have the similiar issue? Or it just me?
Thanks...
Best AnswerIt's not just you. Appears to be a bug in the app since the other goals will update accordingly.
Best Answerthanks pal for the confirmation 🙂
@tastybrew wrote:It's not just you. Appears to be a bug in the app since the other goals will update accordingly.
