If you want to connect any glucose monitor, don't. WHY?
Once you are connected, google won't let you disconnect it and there isn't a way to delete the data or prevent data to be used by Google. Yes, it can't be used by Google ads directly (wink).
Please tell google to allow us to really disconnect and delete the data of google servers
Best AnswerGo to Settings in your (updated) App
Tap Manage Features
Tap Blood Glucose tracking, and choose to turn off.
I just found this option this morning 10/2/23 after dealing with this same issue since March/April and going round and round a few times with support on it. I finally uninstalled my Fitbit app and decided recently I need to get back to monitoring everything and it was still popping up after reinstalling the app.
So far after making above change, I have not gotten an alert this morning, but know they were spaced out several hours before.
Hope this helps!
Best AnswerUpdate, I received a notification this morning 10/3 - so above does not fix it sadly.
