06-19-2019
02:58
12:43
SilviaFitbit
06-19-2019
02:58
12:43
SilviaFitbit
Hi there,
As a cyclist, I use a bike GPS unit and Zwift on my smart trainer. Both are feeding all my rides to Strava.
I enabled the Fitbit <-> Strava synchronisation and if I record a ride using the Exercise > Bike tool on the Inspire HR, it appears in Strava. But rides uploaded to Strava don't appear in the "Recent Exercise" section of the dashboard.
The GPS unit and smart trainer are more accurate, so would it be possible to use the information from Strava instead of recording it on the Inspire?
06-21-2019 09:51 - edited 06-21-2019 09:55
Hi @GrosLapinou welcome to the Community Forums. It's great to have you here.
Thanks for sharing your inquiry about Strava activities. You can check how this app connects with Fitbit here: Third Party Apps - Informational Post -Strava. Activities from Strava are synced over to Fitbit as manually logged activities but will not include GPS or heart rate data from Strava. You will find there some helpful information and instructions on how to troubleshoot syncing issues.
By the way, I'm moving your post to the Third-Party Integrations board for categorization purposes.
I'll be around in case that you need anything else.
Best Answer06-25-2019 15:38
06-25-2019 15:38
Hi
I have the same problem. I would like all my Strava activities to sync and show in fitbit. Including rides in a trainer in zwift.
I followed the link above and it just says they dont ! Which is a bit rubbish. How do we get this resolved so the activities on indoor trainers do sync with FitBit?
06-27-2019 02:24
06-27-2019 02:24
Thanks!
I tried removing / re-adding synchronisation with Strava and rides recorded on the road are now appearing on my Fitbit Dashboard as a manually logged activity.
It's still not great as it creates duplicate entries if I wear the Fitbit whilst riding. So the dashboard sees 2 activities of "riding my bike" at the same time and can't aggregate the data. If I don't wear the Fitbit, it just gets basic information (Start time, distance, and duration).
But virtual rides recorded on Zwift are still not appearing... I had a look at Strava's API, fetching that data is pretty similar to fetching the data from an actual outdoor ride (especially considering you are not retrieving the whole data, just a couple of headers to create a manual entry). An average developer would need an hour tops to figure how to adapt the code to retrieve data for both real and virtual rides and create a manual entry (Start time, duration, distance, calories burnt ).
By the way, Garmin Connect get the whole data (Distance, Heart Rate, Speed, Elevation, Power, Cadence, ... ), no problems.
07-03-2019 05:48
07-03-2019 05:48
@Rcs123 that would depend on your indoor trainer. Does its online account have a link up to Fitbit.
Try searching their help documentation.
Best Answer07-03-2019 06:13
07-03-2019 06:13
It's a Wahoo Kickr, but I don't use the Wahoo App. I do all my indoor sessions directly on Zwift, which then uploads them to Strava.
Fitbit can't link up to Strava for virtual rides, and I haven't seen any signs of integration with Zwift.
02-17-2020 21:29 - edited 02-17-2020 21:30
Hi, I have the same problem. It's really weird that it can't get activities of Strava that come from Zwift as when i do a stationary workout through my gps computer that I sync to Strava, that activity gets sync'ed to Fitbit no problem. Connecting Zwift directly to Fitbit only synchronizes the weight which is useless in that case.
02-17-2020 23:56
02-17-2020 23:56
Have you asked Zwift?
They control what they want to sync.
02-18-2020 05:22
02-18-2020 05:22
No, I haven't. However, since the activities are already sync'ed in Strava, they should be going to Fitbit. But I guess I can try with them see if that is a possibility to sync activities directly into Fitbit. I'll report back if there is fruition. Thanks!
Best Answer02-18-2020 05:39
02-18-2020 05:39
Your saying that Strava is linked to Zwift. And Zwift is linked to Fitbit?
Best Answer02-18-2020 05:45
02-18-2020 05:45
I tried connecting Zwift to Fitbit as a test. but within Zwift, it definitely specifies that it only syncs the weight as you can see below. What really works is Zwift to Strava. But I don't get why these don't get sync'ed to Fitbit afterwards. It really doesn't show like a manual entry in Strava since there is map data, speed, cadence and so on.
02-18-2020 06:00
02-18-2020 06:00
On Strava's Help page I don't see anything that would suggest that Strava recorded exercises will sync over to Fitbit. I do see something about matched runs being displayed on the Ionic Strava app. I'll assume that this would be the same for the Versa Strava app.
Best Answer11-15-2020 03:02
11-15-2020 03:02
Why don’t my zwift activities show up on fit bit
11-15-2020 03:04
11-15-2020 03:04
What do I do
Best Answer11-15-2020 15:48 - edited 11-15-2020 15:49
@Ultimatecraft92 your question is best to ask Zwift. Zwift set up the link to Fitbit, they also maintain the connection.
The only advoce we can give is to revoke Zwift and then setup the link.
Best Answer12-01-2020 10:57
12-01-2020 10:57
I just signed up for Zwift, having also just bought a Wahoo Kickr. Still experimenting. I connected Zwift to Strava and my ride today showed up in my Strava feed this morning, but it doesn't push to the Fitbit. However, after poking around on the Zwift site a bit more, I see that it also connects to Garmin, so I enabled that. I use my Garmin when I'm riding outside.
I will try this out tomorrow to see if it works - my Garmin feeds to my Fitbit, so perhaps this is a workaround? Thoughts anyone?
Best Answer12-08-2020 10:23
12-08-2020 10:23
Best Answer12-08-2020 13:01
12-08-2020 13:01
As long as Zwift has set up a link with Fitbit. Then they will be able to send the rides to Fitbit. Doesn't really need fitbit's permission, since Fitbit wants others to link up.
Best Answer01-22-2021 19:07
01-22-2021 19:07
Strava should really sync to Fitbit for rides done on indoor trainers, it's actually really frustrating that it doesn't.
If I do 3 hard hours on my bike with TrainerRoad or Zwift, Fitbit shouldn't be telling me I need to reach my step goal...
01-22-2021 20:44
01-22-2021 20:44
@BranLan have you added your vote to the request?
