05-30-2017 20:00
05-30-2017 20:00
Can anyone tell me how to connect my fitness pal and the Blaze?
05-30-2017 20:20
05-30-2017 20:20
It has been a while since I did this. I believe you should go to MFP website and then click on the APPS tab. Then on the right click on the step tracker link. Look for Fitbit on the list that shows up and click on the Get button and follow instructions to link the two sites. I believe they will want your Fitbit login info to link.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
05-30-2017 20:20
05-30-2017 20:20
