09-09-2017 15:47
09-09-2017 15:47
I have started using MFP again, which I stopped using when the Blaze stopped synching the two. I really relied on the exercise data that went from my Blaze to MFP, and then suddenly it stopped working. I have disconnected the two apps, signed out of both, and then started all over again trying to link them. I think I have done so, but when I sync, the steps and activity do not show up on my MFP account. Can someone PLEASE HELP?
Best Answer09-09-2017 16:38
09-09-2017 16:38
My suggestion would be to go to https://www.fitbit.com/user/profile/apps
Now revoke access to MFP
Now go to MFP and connect the two accounts.
If this doesn't work the best thing to do is contact MFP since they are responsible for the connection. If there is a problem on Fitbit's side, it should affect every app connectrd. Either way MFP will need to contact Fitbit. Fitbit will not be able to help you directly.
