01-09-2017 09:56
01-09-2017 09:56
I have MyFitnessPal installed and by default it was adding iphone steps and adjusting calories (about 250 extra for 10k steps).
I found the option to instead feed the data from my Fitbit and from similar number of steps it adjusted to allow an extra 800 calories!
Thats a huge discrepancy between the two sources. Does anyone have any ideas which is right and why?
Thanks
Phil.
Best Answer01-16-2017 09:24
01-16-2017 09:24
Hello @PhillyBoy, good to see you again here in the Fitbit Community. Make sure you are not logging activities that could be duplicating your numbers on your Fitbit account. If this is not the case I recommend to re-link both of your accounts, the following instructions shared on this post will be helpful for that purpose.
Hope this helps and let me know if you have additional questions.
