10-16-2017
19:28
06:14
RobertoME
10-16-2017
19:28
06:14
RobertoME
My charge 2 is not synching with the Lose it app and not showing the exercise calorie adjustment any longer?tried restarting the charge2 with no luck
Moderator Edit: Updated Subject For Clarity.
Best Answer10-21-2017 06:11 - edited 10-21-2017 06:13
Hi there @Swampboy, good to see you as a new member of the Fitbit Community! Keep in mind your Charge 2 is not the one syncing with Lose It. Is your Fitbit Dashboard the one in charge to share this data with third party integrations.
Also in the last months, Lose It has gone to premium service to sync with your Fitbit account, so make sure you have enable your Lose It Subscription. You can see a similar discussion from other users here in the following thread: Fitbit and Lose-it require premium subscription.
If you have your Premium subscription and your Fitbit Dashboard is reading your calories correctly from your tracker, try to revoke the access of Lose It from your application settings on your on-line Dashboard. Once you have done this, you can reconnect the integration one more time.
Hope this helps. See you around and for more questions stay tuned to the Fitbit Community!
