03-19-2019 09:02
03-19-2019 09:02
I have my fitbit synced to myfitnesspal. I use a charge 2. For a while this well, but I've started finding the calorie adjustment to be incorrect every few days. It is always under, and by a significant amount (generally 500-1000 calories). I have checked to make sure that both apps have the same goals and time frame inputted, and I tried unsyncing and resyncing the apps to no avail. I don't like to go over my calories on mfp, because that messes up my streak. However, following the incorrect calorie recommendation on mfp leaves me hungry. How can I fix this?
03-20-2019 12:51
03-20-2019 12:51
@inputusername Welcome to the Fitbit Community! I hope you're doing well!
Sorry to hear about the change you are seeing on your calories data. Where are you seeing this change/discrepancy? On the Fitbit app or on MFP? Could you share a screenshot?
I look forward to your reply.
