06-22-2015
11:30
08:38
AngelaMa
06-22-2015
11:30
08:38
AngelaMa
So I have been using myfinesspal for 2 months. Tracking everyday. I recently bought a Fitbit flex and decided to only log in Fitbit app. Has anyone noticed that the calories are not the same? Everything I log is different than my fitness pal. Now I am confused on which one is more accurate. I would like to only log one place!
Best Answer06-22-2015 15:45
06-22-2015 15:45
Make sure that you're logging the same brand and the same portion size. I use LoseIt and Fitbit and have not noticed a significant difference in calorie count.
You say "everything" you log is different - can you provide some examples? This may help the team compare.
You might also want to check some products with known nutrition facts - like milk or a sports drink - and compare what the app gives you with what is actually on the product's nutrition facts.
Collin | Los Angeles, California
One, Charge HR, Aria - Android 5 (Moto X), Mac
Take a look at the Fitbit help site for further assistance and information. Help others while waiting for help!
10-09-2015 09:18
10-09-2015 09:18
@Chriskae Welcome to the Community Forums! Can you confirm if you are still experiencing this discrepancy? I will totally recommend you to link both Fitbit and MFP for both apps to work together. Take a look at this integration article to do it.
Let me know how it goes! ![]()
