02-14-2019
15:15
05:07
LanuzaFitbit
02-14-2019
15:15
05:07
LanuzaFitbit
Really confused. My Fitbit app shows over 5,000 calories as I take, but on MFP (which Fitbit sync with) it is1450. I’ve re-synced from mfp several times and re-synced from Fitbit several times. The crazy 5,000+ calorie number keeps showing up! Not sure what to do. Is this happening with anyone else?
Moderator edit: Labels
Hello @SunsetRunner.
Thanks for letting me know what is going on, I'd like to take a closer look at what is going on.
Could you share some screenshots of the information on both ends? That should let me better understand the situation. Additionally, which end would you say that is the correct one?
Look forward to your reply.
@LanuzaFitbit we use to have a pinned post on how to get the MFP calories to sync correctly. I don't know f the post was unpinned because the problem was rectified or if @SunsetRunner problem is related.
I've also been unable to find the post with a search.
