Calories burned & my fitness pal
Hi there I'm new to having a fit bit.
First of all I'm having trouble syncing my fitnesspal and my blaze. I've linked them and it was working yesterday but today nothing. Also the numbers don't match up. received_10154165974371709.jpeg
I've attached pics. Why are both apps saying different things?
Also is there a way to view on the app or the blaze it's self, my burned calories while active ie steps and exercises WITHOUT seeing the calories my body burns daily on its own.
Thanks in advance x
1 REPLY 1
How you doing my friend @Freyagfab? Welcome! It's great to know that you're using MyFitnessPal to have a better calculation about calories. Sorry about the syncing issues, that must why they are not showing the correct amount of calories. If they are not connecting the numbers won't match up. Please disconnect both Accounts following this steps and then relink them back. It should make them connect, it's best to use the computer to do those steps. Make sure that the Fitbit Account is getting all the information from your Blaze. You will see the last synchronization on your Dashboard. Robot wink
About how to get your calories burn while you're active without the estimated amount that your body burns on its own, you can use any of the option from the Multi-Sport section to view isolated information from the exercise you're performing at that time, it will show the calories burn for that specific workout. Check this video to know how to use it. Also take a look on page 21 on the manual for more information.
Hope this works, I'll be around! Smiley Happy
