05-19-2015
15:04
08:21
AngelaMa
05-19-2015
15:04
08:21
AngelaMa
I've linked Fitbit with My Fitness Pal and although MFP seems to be syncing my steps, my calories burned are not showing up in MFP.
This had led to me wondering if I should ditch MFP and just use the Fitbit app to track movement and food intake! But when I look at the dashboard, Fitbit is not deducting workouts/exercise from my calorie total either.
Basically, I want to monitor my movement and I want calories 'earned' to be added to my calorie total each day. Is there a way to do that in Fitbit? Or figure out why it's no longer recording calories burned/earned in MFP, since I connected it to Fitbit!
05-21-2015 09:54
05-21-2015 09:54
Thank you for stopping by the Fitbit Community @Lizzie75. There have been some issues reported in regard to the connectivity between Fitbit and MFP. My best recommendation is to unlink and relink both accounts. Below you will find the steps you need to follow:
1. Sign into your Fitbit dashboard.
2. Click the gear icon in the upper right corner and select "Settings" from the drop-down menu.
3. On the left side of your screen click "Applications."
4. Under MyFitnessPal, click "Revoke Access."
5. You can then re-link the two accounts by going to http://www.fitbit.com/apps/myfitnesspal.
After relinking, you can verify that your accounts are syncing by using one of the following data points:
1. On Fitbit you can check for your meal summary and logged activities from MFP.
2. On MyFitnessPal, go to "My Home," then "Check-In." You should see your weight, Fitbit Steps, and Fitbit Sleep Minutes.
Please contact me back if you still experience the same.
07-08-2015 14:15
07-08-2015 14:15
07-14-2015 03:24
07-14-2015 03:24
07-15-2016 11:40
07-15-2016 11:40
I am getting nowhere with this so I hope this issue has been resolved since this was posted - I have tried everything regarding restarting and reconnecting and disconnecting and logging in and logging out and there is just literally no Fitbit data going into MyFitnessPal. When I go to "Check In" as you describe, there is no information. No steps tracked, no calories burned, nothing. However, MyFitnessPal's data is going into Fitbit easily - calories eaten, etc. Also, shouldn't FitBit add calories to my daily intake after a workout? I'm very confused about all that as well.
It is sounding like I should just log all food into Fitbit and give up on MFP. I was really excited about the coordination between the two apps but I just don't think they actually work together.
07-15-2016 15:02
07-15-2016 15:02
08-16-2016 11:20
08-16-2016 11:20
Melissa - I did all these steps (3x - just in case I messed it up), and I still get no calorie adjustment in MyFitnessPal. I see my calories in FitBit from MyFitnessPal though. Was there an App Update that would cause these two to stop talking?
09-19-2016 06:30
09-19-2016 06:30
Hi there @dgainey13, @MEVandiver and @Theo1967. I was revisiting this post and it seems its been a while since you posted.
Actually I agree with @Theo1967 comments. most of the times what I see other users do, I include myself too is to leave MFP specifically for food logging due to the variety of the food data base. Regarding the exercises can be use both, either Fitbit or MFP, however in this case is just matter to be careful in order to avoid duplicate activities. In some occasion the tracker may detect an activity that was previously logged on MFP. But as you said once you get along on how it works, it provide more options for keep track of your healthy lifestyle.
@MEVandiver, @dgainey13. MFP and Fitbit should sync instantaneously. There may be an occasional 3-5 minute delay but it shouldn't take longer than this. So far there has not been made recent changes on how the information is shared between these integrations.
This is the chart of the information shared between both accounts:
Fitbit > Steps > MFP |
Fitbit > Calories > MFP |
Fitbit > Aria measurements > MFP |
MFP > Logged food > Fitbit |
MFP > Activities > Fitbit |
When there is a difference in calorie estimations between Fitbit and MFP, MFP makes a "Fitbit Calorie Adjustment. The adjustment represents calories burned above MFP's estimate and will update each time Fitbit syncs. If this is not working the only solution is what you have tried by revoking the access. Unfortunately we do not provide specific support for using the MyFitnessPal mobile apps or website.
I know there was an issue from MFP pal's end where the calories from Fitbit were not syncing but I 'm not aware if the issue still persist or under what circunstance happened this, so other recommendation would be to review with the guys from Support of MyFitnessPal if the issue persist.
See you around and if you have more questions, I'll be around.
01-04-2017 03:16
01-04-2017 03:16
Hi Melissa,
I'm still facing the same problem as @Lizzie75. MyFitnessPal is syncing the steps from Fitbit only, but not my workouts. This means a huge gap between burned kcal from Fitbit versus what I see in MyFitnessPal. How can I adjust this?
01-04-2017 12:22
01-04-2017 12:22
I'm really hoping you get a response (more informative than this...) as I'm having the same issue.
Steps and sleep minutes are being tracked, but my exercise calories are not carrying over to MyFitnessPal. I've also been looking through threads for over an hour and haven't come across a resolution. I can't imagine MFP would consider over 500 calories burned to be negligible and not worthy of an adjustment.
01-07-2017 01:18 - edited 01-07-2017 01:29
I am also having issues with linking. I thought MFP will adjust exercise calories based on burned calories in fitbit, so far I have 0 there. I can already see calories from my food log in fitbit and how many calories are remaining. In MFP I see steps and sleep minutes.
The essential feature I've expected is to count calories from food and exercise, giving me a quick glance in MFP of how many calories are remaining for a day. Is this not working and I should check it in fitbit?
I've already tried relinking my account.
EDIT: I think I've found a solution. You have to select Fitbit tracker as source for your steps in MFP. It's on https://www.myfitnesspal.com/apps/step_trackers After this and sync, my calories from exercise were adjusted.
01-11-2017 21:23
01-11-2017 21:23
I have the same problem. Steps are synced, from fitbit -> MFP Food is synced from MFP -> fitbit. Calories burned are not sent from fitbit -> MFP. This used to work and now doesn't. Not sure what is going on but it is frustrating.
01-12-2017 08:37
01-12-2017 08:37
What phandox mentioned above worked for me.
Although your steps may be syncing to MFP as mine were, there was another setting on the MFP website that needed to be enabled; go to myfitnesspal.com, select the "Apps" tab and then the "Steps" tab beneath it.
From here you should be able to select Fitbit Tracker, which I thought was far from intuitive and should have been enabled by default when syncing the apps... In any case this did the trick for me and I've had no issues with my calorie adjustment syncing with MFP since then.
03-24-2017 05:07
03-24-2017 05:07
If you log into MFP and go into "Steps" in the settings menu and select "fitbit" instead of your mobile phone.. 🙂
03-25-2017 08:00
03-25-2017 08:00
Hello @gromnislash, @SunsetRunner and welcome aboard @KayDM, @Norahben. The best recommendation when the information is not share across MFP with Fitbit is to revoke the access to reset the integration although there are a few things to try additional to this.
If the calories are not being adjusted between Fitbit and MFP I can recommend the following post: MyFitnessPal: How to correct calorie discrepancy from MFP to Fitbit.
Also another setting is important to review is to enable the tracker on MFP as a device from where is recording your steps a it was mentioned before.
If the exercise are not syncing or you need to enable this settings perhaps the following post might be of your help.
See you around. Let me know if you have additional questions.
03-28-2017 23:49
03-28-2017 23:49
I have tried everything suggested here, including revoking access to mfp and then re-linking, disconnecting my fitbit from mfp and then reconnecting, logging in and out of both apps, resetting calorie goals in both apps, and selecting the fitbit in my steps in mfp.
I am able to see steps from my fitbit, but when I go to my exercises in mfp, no exercise is recorded. Additionally, when I view calories burned, no calories from my fitbit are synced with mfp. So, it is syncing some data, but not the calories/exercise. I know this is supposed to updated automatically, but nothing shows. There is nothing there for caloric adjustments (the issue is not that the adjustment is zero, but that there is NO adjustment showing at all, not even zero).
Any peeps still having issues with this in 2017?
03-28-2017 23:51
03-28-2017 23:51
My issue is that steps ARE showing in mfp, but not calories burned! So weird.
04-10-2017 09:30
04-10-2017 09:30
Hello @resistance, let me start by giving you a warm welcome to the Fitbit Community. It's been a few weeks since you posted, so I'm wondering how it goes? Is the issue still persisting? Did you tried my previous recommendation about How to correct calorie discrepancy from MFP to Fitbit?
If you have and the issue still persists, please approach to MyFitnessPal support for more details. I been looking if there is an issue from our end, but so far there are no reports of a glitch.
Let me know if you have more questions. See you around.
04-10-2017 14:13
04-10-2017 14:13
Hi Everyone!
I am having a similar problem, but it's because I had an old MyFitnessPal account linked to my Flex at one point. Though I deleted the old MFP account, when I try to link my Flex to the new account it won't let me. Says "another MFP account is already linked to this tracker." Problem is there is no old account to go back to anymore to do the "disconnect." Any ideas how to rid my Flex of this old MFP ghost? Thanks!
04-10-2017 14:30
04-10-2017 14:30
UPDATE: I waited until the following day and the calories burned showed up! Guess I just needed to give it some time moving forward; it did not upload for past info.
