02-18-2015 05:59
02-18-2015 05:59
I use TrainingPeaks to log my triathlon training and I use my FitBit Charge HR as my heart rate monitor. I was wondering if there is a way to link the fitbit app and the TrainingPeaks app?
02-21-2015 07:31
02-21-2015 07:31
It's not possible to link apps directly to the Fitbit App, however Fitbit offers the ability for other developers / companies to create a link between their app and the fitbit account (when giving your permission), so it's possible to use for example their program to log food and it sync's to the fitbit account.
Fitbit however doesn't have any control over other apps since these aren't developed by Fitbit. If it's not possible to link to the fitbit account in the TrainingPeaks app to sync certain information, feel free to contact the 'TrainingPeaks' app Support Team to request integrating such functionality.
02-21-2015 09:33
02-21-2015 09:33
12-11-2015 10:34
12-11-2015 10:34
so that was almost a year ago. i just started using TP. have you found a bridge between the two?
01-01-2016 11:27
01-01-2016 11:27
As an avid user of trainingpeaks, I would make my decision of my next activity tracker and scale based on whether or not the data could be imported to TP. I know both Garmin's tracker and scale can. I love my Fitbit but there many other products and all my historic data is with TP. Is this something y'all are looking into?
01-28-2016 10:15
01-28-2016 10:15
I'd suggest we ping training peaks to support this...it's already on their radar, perhaps if you guys consider 'voting' for this functionality on their wish-list project ideas:
06-09-2016 18:46
06-09-2016 18:46
08-10-2016 10:27
08-10-2016 10:27
any updates on this?
08-11-2016 10:51
08-11-2016 10:51
@wytown88 I responded to something similar here, but essentially they would have to build the integration using our open Web API if you want data to sync between the two services.
Aside from that, Fitbit devices will only communicate directly to Fitbit apps and will not connect to third party applications. That would require a Bluetooth SDK. I don't know of any current plans for that, but I'm assuming if it were to happen it would only be for newer devices.
04-09-2017 00:56
04-09-2017 00:56
Any updates, my understanding is the primary problem is that FitBit do not provide the required time stamp data, while I do not want to throw away the investment made in FitBit including the scale etc, this is a bit of a show stopper for me. Unfortunately found Training peaks app after my investment in FitBit so in a quandary at the moment. Also does not link to other training programs like Strava etc. FitBit seem to be holding a more proprietary integration approach which does not really work for me. Would like to confirm what is in the road map. I think FitBit are missing the point, Application drives adoption, this is the key to the success of products like Garmin and Android where they have made their devices compatible, are FitBit going to do the same or should I move to Garmin, not a threat just don't want to waste time if FitBit are not going to work on their compatibility and rather cut my losses sooner rather than later.
09-23-2017 03:40
09-23-2017 03:40
Yes you can use a thirdparty service for example: FitnessSyncer.
More information at the Trainingpeaks website:
https://help.trainingpeaks.com/hc/en-us/articles/115001917608
I hope this helps
08-23-2018 10:20
08-23-2018 10:20
I realize that this thread is a bit old, but just incase anyone new comes across this I wanted to let everyone know that we are currently beta testing an auto-sync of workout and body composition data from Fitbit to TrainingPeaks. At this time we are not syncing sleep or step data. If you would like to test this new feature you can connect your accounts using the link below. After connecting your accounts, new workouts and body composition measurements will automatically sync from your Fitbit account to your TrainingPeaks account.
https://www.trainingpeaks.com/account/fitbit
Please send feedback on this feature to beta@trainingpeaks.com and let us know how it is going!
You can keep track of our progress on this feature here:
Ben
