03-09-2014 18:46
03-09-2014 18:46
I am new to fitbit. Is there a way to transfer my data from Myfitnesspal.com to my fitbit?
Best Answer03-09-2014 19:10
03-09-2014 19:10
Yes...you can sync My Fitness Pal to your fit bit. If you log into My Fitness Pal it will give you the option to sync a device. I did it via my lap top using My Fitness Pal account.
Just be sure to log food and exercise to My Fitness Pal when synced with your fit bit and not the other way around. There's a known bug if you try to log food/exercise on the fit bit log when synced to My Fitness Pal
So...when the two apps are synced....
@marnet10 wrote:I am new to fitbit. Is there a way to transfer my data from Myfitnesspal.com to my fitbit?
Log food and exercise into My Fitness Pal ----> Good
Log food and exercise into fit bit -----> Bad
09-25-2016 10:23
09-25-2016 10:23
I'm not sure what ese to look for. I am trying to sync my fitness pal with fit bit on my lap top. My fitness pal says it is synced with fit bit but no food entries or nutrition are moving over to the fit bit food diary. I have an android unit.
