02-04-2019
13:24
04:40
LanuzaFitbit
02-04-2019
13:24
04:40
LanuzaFitbit
Hi, I'm getting so frustrated with my phone I'm trying to connect my charge 2 (the fitbit app) with my fitness pal but it won't connect. I've tried with both the internet site and the mobile app but nothing. I've gone through the steps others mentioned by doing it through m6 fitness pal but I get so far and it just opens the fitbit app but hasn't connected
When I try and select 'compatible apps on the fitbit app it doesn't do anything
Can anyone offer any suggestions??
Best Answer02-05-2019 04:37
02-05-2019 04:37
Welcome to the Forums @K3114.
Thanks for sharing all of the steps that you have tried.
In this case I'd recommend that you try to get in touch with MFP directly. Given that these integrations are developed by the third parties, they should be able to take a closer look at what is going on.
Let me know if you have any further questions.
